1) PNP graph units, for CPU utilization showing upto 120%, this should be 100%. Please find screenshot.
2) Need to unit "m" showing in second screen shot.
3] Share doc / details understand all unit type in pnp graph and how to change as per requirement.
pnp4nagios graph units
Re: pnp4nagios graph units
Please see here:
OR here (depending on your version of PNP4Nagios):
See here as well:
Let us know if you have any questions.
https://docs.pnp4nagios.org/pnp-0.6/tpl
https://docs.pnp4nagios.org/pnp-0.4/tpl
http://askaralikhan.blogspot.com/2010/01/creating-custom-template-in-pnp4nagios.html
Also, the "m" is coming from the performance data returned by the plugin so you may need to modify that - http://nagios-plugins.org/doc/guidelines.html#AEN200
