Hello ..
i have a very old version of nagios which is 3.2.0. Currently i have installed newer version nagios core 4.4.5 onto another server (centos 7) and want to move all hosts and configuration to the new server. I am very new to this nagios and need a help to do that. Please help me out..
Upgrade nagios core from 3.2.0 to 4.4.5
Re: Upgrade nagios core from 3.2.0 to 4.4.5
You should have a number of configuration file in /usr/local/nagios/etc/. It's probably best to just tar up the entire /usr/local/nagios/etc/ directory, and copy it to the 4.4.5 server, and then untar it. You will likely run into some syntax errors in the configuration files. You can use the following command to verify your files, and find any syntax errors before you attempt to start up Nagios Core.
Thanks for your reply mbellerue, I got these files/folders under /etc but nothing in /usr/local directory.
/etc/nagios3
apache2.conf cgi.cfg commands.cfg conf.d htpasswd.users nagios.cfg nagios.cfg.ori nagvis resource.cfg stylesheets
/etc/nagios-plugins
config
/etc/nagiosql
backup contactgroups.cfg contacttemplates.cfg hosts servicegroups.cfg servicetemplates.cfg
commands.cfg contacts.cfg hostgroups.cfg hosttemplates.cfg services timeperiods.cfg
So please suggest what can i do now?
/etc/nagios3
/etc/nagios-plugins
config
/etc/nagiosql
I would take nagios.cfg from /etc/nagios3, and copy it to /usr/local/nagios/etc/ on the new system.
Then all of the files from /etc/nagiosql, and copy them to /usr/local/nagios/etc/objects/ on the new system.
Likely you will want to look through these config files, specifically nagios.cfg, and make sure that any paths are updated from /etc/nagios3 to /usr/local/nagios/etc. There will likely also be configuration syntax changes. This will help you track down the changes that need to be made. /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
After changing lots of settings i got it working but hosts are not working.
Nagios Core 4.4.5
Last Modified: 2019-08-20
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 15 services.
Checked 4 hosts.
Checked 73 host groups.
Checked 0 service groups.
Checked 11 contacts.
Checked 10 contact groups.
Checked 26 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 4 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Can you say me where can i put differenthosts.cfg into?
Nagios Core 4.4.5
License: GPL
Checking objects...
Checked 4 hosts.
Checked 4 hosts
Total Warnings: 0
Total Errors: 0
In Nagios 4.4.5, configuration files are kept in /usr/local/nagios/etc/objects/. That is where your new hosts configuration file should go.
