Initially sorry for my english.
I'm new to Nagios, and I'm just trying to install the NRPE plugin on the nagios server to get information from windows machines.
After running or downloading NRPE while trying to follow the installation (https://github.com/NagiosEnterprises/nrpe or https://assets.nagios.com/downloads/nag ... e/NRPE.pdf) encountering the difficulty .
I was having the same error on the post: https://support.nagios.com/forum/viewto ... =7&t=41604
Following a user recommendation and installing libssl-dev, I am now encountering another error.
After executing "./configure" in the NRPE folder, follow the return:
config.status: error: cannot find input file: `Makefile.in '
Following complete return:
root@security2:~/dados/nrpe-master# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking what the operating system is ... linux
checking what the distribution type is ... debian
checking what init system is being used ... systemd
checking what inetd is being used ... systemd
checking for which paths to use ... default
checking for which init file to use ... default-service
checking for which inetd files to use ... default-socket
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether make sets $(MAKE)... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking whether time.h and sys/time.h may both be included... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking for inttypes.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking pwd.h usability... yes
checking pwd.h presence... yes
checking for pwd.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for stdint.h... (cached) yes
checking for strings.h... (cached) yes
checking for string.h... (cached) yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking tcpd.h usability... no
checking tcpd.h presence... no
checking for tcpd.h... no
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking socket.h usability... no
checking socket.h presence... no
checking for socket.h... no
checking for sys/types.h... (cached) yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking for sys/wait.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking for sys/stat.h... (cached) yes
checking paths.h usability... yes
checking paths.h presence... yes
checking for paths.h... yes
checking for an ANSI C-conforming const... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for mode_t... yes
checking for pid_t... yes
checking for size_t... yes
checking return type of signal handlers... void
checking for uid_t in sys/types.h... yes
checking type of array argument to getgroups... gid_t
checking size of int... 4
checking size of short... 2
checking size of long... 8
checking for uint32_t... yes
checking for u_int32_t... yes
checking for int32_t... yes
checking for struct sockaddr_storage... yes
checking for seteuid... yes
checking for va_copy... yes
checking for vsnprintf... yes
checking for snprintf... yes
checking for asprintf... yes
checking for vasprintf... yes
checking for C99 vsnprintf... yes
checking for getopt_long... yes
checking for main in -lnsl... yes
checking for socket in -lsocket... no
checking for main in -lwrap... no
checking for strdup... yes
checking for strstr... yes
checking for strtoul... yes
checking for strtok_r... yes
checking for initgroups... yes
checking for closesocket... no
checking for sigaction... yes
checking for scandir... yes
checking for socklen_t... yes
checking for type of socket size... size_t
checking for Kerberos include files... configure: WARNING: could not find include files
checking for pkg-config... pkg-config
checking whether compiling and linking against SSL works... yes
checking for openssl... /usr/bin/openssl
*** Generating DH Parameters for SSL/TLS ***
Generating DH parameters, 2048 bit long safe prime, generator 2
This is going to take a long time
checking for perl... /usr/bin/perl
configure: creating ./config.status
config.status: error: cannot find input file: `Makefile.in'
