I repeated the process as indicated and it worked, I believe I failed one of the steps.scottwilkerson wrote:What was the output when you ranbecause it doesn't look like that happenedCode: Select all
make check_nrpe
Before I had repeated this same process as manual, but I believe I did not have the prerequisites, so I could not pass "MAKE"
Now "ckeck_nrpe" is already in the libexec folder.
I appreciate your commitment to solving my problem.
Returns:
# make check_nrpe
cd ./src/; make
make[1]: Entering directory '/tmp/nrpe-nrpe-3.2.1/src'
gcc -g -O2 -DHAVE_CONFIG_H -I ../include -I ./../include -o nrpe ./nrpe.c ./utils.c ./acl.c -lssl -lcrypto -lnsl
./nrpe.c: In function ‘read_config_dir’:
./nrpe.c54: warning: ‘%s’ directive output may be truncated writing up to 255 bytes into a region of size 254 [-Wformat-truncation=]
snprintf(config_file, sizeof(config_file) - 1, "%s/%s", dirname, dirfile->d_name);
In file included from /usr/include/stdio.h:862:0,
from ../include/config.h:31,
from ./nrpe.c:37:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:64:10: note: ‘__builtin___snprintf_chk’ output 2 or more bytes (assuming 257) into a destination of size 255
return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
__bos (__s), __fmt, __va_arg_pack ());
gcc -g -O2 -DHAVE_CONFIG_H -I ../include -I ./../include -o check_nrpe ./check_nrpe.c ./utils.c -lssl -lcrypto -lnsl
make[1]: Leaving directory '/tmp/nrpe-nrpe-3.2.1/src'
root@sexxxxxx2:/tmp/nrpe-nrpe-3.2.1# make install-plugin
cd ./src/; make install-plugin
/usr/bin/install -c -m 755 -d /usr/local/nagios/bin
/usr/bin/install -c -m 755 ../uninstall /usr/local/nagios/bin/nrpe-uninstall
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/libexec
/usr/bin/install -c -m 775 -o nagios -g nagios check_nrpe /usr/local/nagios/libexec
