Hi !!!
I have a validation problem when executing a command to monitor vmware.
If I execute the command with root user it works for me
./check_vmware_api.pl -H serveresxi -u root -p password -l cpu
CHECK_VMWARE_API.PL OK - cpu usage = 9862.00 MHz (14.67%) | cpu_usagemhz = 9862.00 ;; cpu_usage = 14.67% ;;
But with the domain user nagiosusr I get validation error.
The user in vmware is registered with the role read, as indicated in the documentation of the plugin.
./check_vmware_api.pl -H serveresxi-u nagiosusr -p password -l cpu
CHECK_VMWARE_API.PL UNKNOWN - Error: Cannot complete login due to an incorrect user name or password
I have tried with
nagiosusr@domain
domain\nagiosusr
domain\\nagiosusr
but it gives the same validation error
Any more options?
Thank you
Check_esx error domain user
Re: Check_esx error domain user
Is there special chars in both? Try surrounding with single-quotes like below:
./check_vmware_api.pl -H serveresxi -u 'nagiosusr' -p 'password' -l cpu
the user does not contain special characters, the password if ... I have added the quotes, but still giving the same invalid username or password error
Send the FULL output of this one:
./check_vmware_api.pl -H serveresxi -u 'nagiosusr' -p 'password' -l cpu -vvv --trace=4
[root@server nagios plugins]# ./check_vmware_api.pl -H server -u 'nagiosusr' -p 'xxxxxxx' -l cpu -vvv --trace=4
[extra-opts] check_vmware_api.pl -H server-u nagiosusr -p xxxxxx -l cpu -vvv --trace=4
CHECK_VMWARE_API.PL UNKNOWN - Error: Cannot complete login due to an incorrect user name or password.
thanks !!!
thanks !!!
I just re-verified domain user login should be in this format:
Make sure that the user you are using has all the required permissions to view details on the server
./check_vmware_api.pl -H 192.168.7.20 -u 'user@domain.ext' -p 'password' -l cpu
CHECK_VMWARE_API.PL OK - cpu usage=11058.00 MHz (27.10%) | cpu_usagemhz=11058.00;; cpu_usage=27.10%;;
