Host check issue
Host check issue
Host definition from template.cfg.
We are using passive check
max_check_attempts 1
check_interval 1
retry_interval 1
active_checks_enabled 0
passive_checks_enabled 1
In critical, shwoing soft state, want to hard state to sent notification.
Host status update taking 10 min to get status details.
Please help to fix this issue.
check_interval 1
retry_interval 1
Re: Host check issue
In the nagios.cfg
change this
to this
and restart nagios
change this
passive_host_checks_are_soft=1
already updated in nagios.cfg
What version of Nagios Core are you running?
These should be HARD by default, but there were a few bugs in early 4.4.x that could cause this behavior.
We are using
Nagios core version : 4.3.4
Can you show an example of one of these?
Can you show the whole configuration for this host (obfuscating any sensitive info)?
Question :
What is importance of freshness_threshold in host passive check, if this is zero or not defined, ok with host definition, any impact on server resource utilization.
We have nagios core server version 4.3.4 with 1000 host and 80k services monitoring
freshness_threshold
When the freshness_threshold is reached, an active check is performed if check_freshness is enabledThis directive is used to specify the freshness threshold (in seconds) for this host. If you set this directive to a value of 0, Nagios will determine a freshness threshold to use automatically.
