Failed to start Nagios Core 4.4.5.
vho
Post by vho »
Running Nagios Core 4.4.5 on CentOS 7
Unable to start Nagios service.
v 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: Error: Could not add object property in file '/usr/local/nagios/etc/OZ/templates.cfg' on line 69.
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: Error: Invalid max_check_attempts value for host 'AWSSRVPRDIIS01'
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: Error: Could not register host (config file '/usr/local/nagios/etc/OZ/hosts.cfg', starting on line 710)
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: Error processing object config files!
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: ***> One or more problems was encountered while processing the config files...
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: Check your configuration file(s) to ensure that they contain valid
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: directives and data definitions.  If you are upgrading from a previous
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: version of Nagios, you should be aware that some variables/definitions
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: may have been removed or modified in this version.  Make sure to read
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: the HTML documentation regarding the config files, as well as the
Nov 26 14:22:45 DALSRVITMON01.oz.local nagios[3148]: 'Whats New' section to find out what has changed.
Nov 26 14:22:45 DALSRVITMON01.oz.local systemd[1]: Failed to start Nagios Core 4.4.5.
-- Subject: Unit nagios.service has failed
-- Defined-By: systemd
services.cfg
(36.09 KiB) Downloaded 316 times
nagios.cfg
(44.32 KiB) Downloaded 302 times
hosts.cfg
(18.63 KiB) Downloaded 250 times
vho
Re: Failed to start Nagios Core 4.4.5.
Post by vho »
Attaching the commands.cfg and templates.cfg files as well.
templates.cfg
(12.24 KiB) Downloaded 301 times
commands.cfg
(14.32 KiB) Downloaded 253 times
vho
Post by vho »
Thread can be closed. I was able to resolve the issue by correcting the config files.
ssax
Dreams In Code
Post by ssax »
Please remove your duplicate host and service templates entries from your hosts.cfg file (some are already in your templates.cfg):
register 0 = template
Here's an easy way to find them for you:
grep -B15 'register 0' /usr/local/nagios/etc/OZ/hosts.cfg
Just make sure they are in the templates.cfg before removing from the hosts.cfg.
ssax
Dreams In Code
Post by ssax »
Sounds good, closing now.
