I have been cracking my head with check_snmp_printer plugin. Fortunately I was able to get all the printers show correct information except one. Problematic printer will give me an error like that: "Plugin check_snmp_printer failure - snmpwalk command error. "
If I run check_snmp_printer on plugins folder:
[root@nagios libexec]# ./check_snmp_printer -H [IP] -C public -t "STATUS"
Timeout: No Response from [IP]
[root@nagios libexec]# ping [IP]
PING [IP] ([IP]) 56(84) bytes of data.
64 bytes from [IP]: icmp_seq=1 ttl=255 time=0.197 ms
64 bytes from [IP]: icmp_seq=2 ttl=255 time=0.177 ms
SNMPv2-MIB::sysDescr.0 = STRING: HP ETHERNET MULTI-ENVIRONMENT,SN:CNGTKDW182,FN:N182ZGZ,SVCID:28082,PID:HP Color LaserJet CP5225n
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.11.2.3.9.1
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (10935381) 1 day, 6:22:33.81
SNMP
Status: Read-Write Access Enabled
SNMP Version: v1
Any help would be more than appreciated, tried to Google the issue, but there are not many answers regarding to that plugin unfortunately.
Thank you in advance and all the best,
Kukkurloom.
