Nagios Core
Nagios Core
How to monitor different networks in Nagios core
Re: Nagios Core
Can you elaborate on what you are trying to accomplish?bhaskar.n wrote:How to monitor different networks in Nagios core
Re: Nagios Core
ISP1 -Network 1 : 192.168.1.1 (Nagios Installed)
ISP2- Network 2 : 10.10.10.1
Nagios core installed in network 1 (192.168.1.1) and monitoring Network 1 servers.
Note: There is no communication between Network1 and Network2.
Is it possible to monitor Network 2 (10.10.10.1) servers from Network 1 (Nagios core)?
Re: Nagios Core
Not unless you create some sort of communication channel such as a VPNbhaskar.n wrote:Note: There is no communication between Network1 and Network2.
Re: Nagios Core
Still looking for other options.
Re: Nagios Core
If you cannot have any communication between these two networks, then I would recommend installing another Core instance on ISP2.
