Hi
Im trying to create an event handler to affect a hostgroup service.
I want the eventhandler to affect only the host that has a service affected and I am not sure I am doing this correctly.
What I have configured:
use generic-service,service-pnp
hostgroup_name ourgroup
service_description CHECK ASERVICE SERVICE
check_command check_nrpe!check_aservice_server
max_check_attempts 3
check_interval 5
retry_interval 1
check_period 24x7
notification_interval 60
notification_period 24x7
contacts theadmin
event_handler_enabled 1
#event_handler restart-aservice
command_name restart-aservice
command_line $USER1$/eventhandlers/restart-aservice $SERVICESTATE$ $SERVICESTATETYPE$ $SERVICEATTEMPT$ $HOSTNAME$
Please is this correct?
How to add $HOSTNAME$ to hostgroup service eventhandler
Re: How to add $HOSTNAME$ to hostgroup service eventhandler
That looks correct to me, with the exception that the event_handler line is commented outsinaowolabi wrote:Please is this correct?
Thanks a lot!
Sorry the commented line was an oversight.
- Box293
- Too Basu
An easy mistake any one of us has made at some point
Is there anything else in relation to this that you need help with or can we lock this thread?
