We have nagios core 4.4.5 running on CentOS 7 (core)
We monitor ~75 vpn tunnels we have connected to our clients and all of the sudden a huge chunk just stopped working with the error
CRITICAL! VPN peer X.X.X.X unavailable.
this is the command we use
use vpn-service
host_name DALASA01_Primary
service_description ARL_To_VW
check_command check_tunnel!X.X.X.X
However we have about 5 tunnels that are showing okay. and its the SAME command just different IP
Avera
Perform Extra Service Actions
OK 02-17-2020 12:51:48 23d 23h 25m 24s 1/3 OK! VPN peer X.X.X.X available.
use vpn-service
service_description Avera
check_command check_tunnel!198.179.214.5
We inherited this box from the previous IT person and we have not made any changes to the vpn tunnel cfg file
I can ping the IP's that are showing down and they do respond back, our ASA shows them to be connected. Im at a loss here, any help would be appreciated
VPN tunnel monitoring died
- Box293
- Too Basu
Re: VPN tunnel monitoring died
Can you please post your command definition for check_tunnel
command_name check_tunnel
command_line $USER1$/check_asa_vpn.pl -H 10.10.15.5 -C oz -P $ARG1$
found it
- Box293
- Too Basu
On your nagios server can you execute the following command as the nagios user:
FYI
$USER1$ = /usr/local/nagios/libexec but may be different in your environment (it's defined in resources.cfg)
/usr/local/nagios/libexec/check_asa_vpn.pl -H 10.10.15.5 -C oz -P 198.179.214.5
FYI
it shows up as okay.
we may have found the issue. It may be with the ASA, opened up the code of the check_asa command, and ran the snmp walk against the asa and it is only spitting out 9 active 'OK' tunnels.
- Box293
- Too Basu
Let us know how you go and if you need more help.
