I have a requirement to not issue a notification, unless the failure occurs 3 times.
is this possible in configuring Nagios Core?
Step 3: Raise Alarm if three consequetive calls fail.
Nagios configuration question on triggering a notification
Re: Nagios configuration question on triggering a notificati
Yep, in the host/service definition set
This will wait until it fails 3 times before sending notification
max_check_attempts 3
thank you !!! I'll get there some day. appreciate it. you guys are the best!
No problem.gmills wrote:thank you !!! I'll get there some day. appreciate it. you guys are the best!
Locking thread
