my define service
host_name BTP
service_description SQL
check_command check_mssql_database.py -H BTP -U nagios -P XXXX -T XXXXXX -p 1433 --cpu -w 50 -c 80
not working , can someone give me an example of how to define correctly the service of this plugins?
mssql_server.py
mssql_server.py define service not work
- Box293
- Too Basu
Re: mssql_server.py define service not work
You need to define a command. This documentation provides an example:
https://assets.nagios.com/downloads/nag ... ndows.html
Please refer to the section "Create the check command definition"
Also, definitely keep this link around. This document contains all of the information you need to define every type of object in Nagios Core. Complete with examples.
