Nagios worked well and peachy until recently, so there was no need to write or report anything until few days ago it just broke after occasional packages upgrade. Note: I did not upgrade Nagios version in a while, so could be conflict at that end as well.
Nagios in web is loading up front page, when I click to login in and add data it just spins endlessly.
Nagstamon is gray, not listing any servers its monitoring and showing only error - IndexError: list of index out of range
On server side it is on failed state.
Here is journalctl -xe with error:
-- The start-up result is done.
Apr 22 11:19:02 nagios CROND[17451]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/deadpool.php >> /usr/local/nagiosxi/var/deadpool.log 2>&1)
Apr 22 11:19:02 nagios systemd[1]: Started Session 115387 of user nagios.
-- Subject: Unit session-115387.scope has finished start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit session-115387.scope has finished starting up.
Apr 22 11:19:02 nagios systemd[1]: Started Session 115386 of user nagios.
-- Subject: Unit session-115386.scope has finished start-up
-- Unit session-115386.scope has finished starting up.
Apr 22 11:19:02 nagios systemd[1]: Started Session 115382 of user nagios.
-- Subject: Unit session-115382.scope has finished start-up
-- Unit session-115382.scope has finished starting up.
Apr 22 11:19:02 nagios systemd[1]: Started Session 115380 of user nagios.
-- Subject: Unit session-115380.scope has finished start-up
-- Unit session-115380.scope has finished starting up.
Apr 22 11:19:02 nagios CROND[17454]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php >> /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Apr 22 11:19:02 nagios CROND[17455]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php >> /usr/local/nagiosxi/var/reportengine.log 2>&1)
Apr 22 11:19:02 nagios CROND[17456]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php >> /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Apr 22 11:19:02 nagios CROND[17457]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/snmptt_service_results.php >> /usr/local/nagiosxi/var/snmptt_service_results
Apr 22 11:19:02 nagios CROND[17458]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php >> /usr/local/nagiosxi/var/cleaner.log 2>&1)
Apr 22 11:19:02 nagios CROND[17459]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php >> /usr/local/nagiosxi/var/eventman.log 2>&1)
Apr 22 11:19:02 nagios CROND[17460]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/event_handler.php >> /usr/local/nagiosxi/var/event_handler.log 2>&1)
Apr 22 11:19:02 nagios CROND[17461]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php >> /usr/local/nagiosxi/var/feedproc.log 2>&1)
Apr 22 11:19:02 nagios CROND[17462]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php >> /usr/local/nagiosxi/var/sysstat.log 2>&1)
Thanks in advance
