Hi
I am having issue excluding services including spaces using check_nrpe.
If I use, everything works ok:
command_name check_service
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckServiceState -a CheckAll exclude=$ARG1$
check_command check_disk!LanmanServer
But as soon as I change to:
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckServiceState -a CheckAll "exclude=$ARG1$"
check_command check_disk!ManageEngine AssetExplorer Agent
I get this error:
Could not construct return packet in NRPE handler check client side (nsclient.log) logs...
Could someone please help I have read all the documentations, and I am sure I have the right syntax.
Thanks in advance.
CheckNRPE CheckServiceState with Exclusions including Spaces
Re: CheckNRPE CheckServiceState with Exclusions including Sp
The exclude statement only accepts one service per exclude declaration. So this is probably better:
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckServiceState -a CheckAll $ARG1$
check_command check_disk!exclude=ManageEngine exclude=AssetExplorer exclude=Agent
Thanks for The Reply:
I changed to:
check_command check_disk!exclude="ManageEngine AssetExplorer Agent"
The problem is now that its slitting the service same into words, instead of just sending whole string.
This is what it's doing.
2012-05-18 12:38:54: debug:NSClient++.cpp Injecting: CheckServiceState: CheckAll, exclude="ManageEngine, AssetExplorer , Agent"
I changed to:
Re-read my reply, very carefully you missed a very important part of it.
I understand that you can only use one exclude statement.
In this exable the actual service name is "ManageEngine AssetExplorer Agent"
Not three different services.
