Hi guys,
I have Nagios 3.2.0 monitoring a large number of host and services (2k services).
Almost all of them are passive checks posting their service status directly on the cmd file using a custom application.
The status of these services is posted each 2 minutes in huge blocks all at the same time.
Then I have a little group of active checks scheduled each 3/4 minutes.
Looking at Nagios the status of passive checks is always up to date while active checks are almost never been executed (often I see next scheduled check in the past, in 1970...)
I have tried almost everything using the tuning options, cache, timeouts, also diabling the interleave factor.
It seems that when the number of passive checks posting is over a certain threshold... bye bye to active checks.
Any suggestion?
It's really frustrating. Can I give priority to active checks against external commands?
Angelo
Passive checks vs Active checks
Re: Passive checks vs Active checks
I found an answer RTFM: "Each time Nagios checks for external commands it will read and process all commands present in the command file before continuing on with its other duties."
So if you have a lot of stuff processed as external commands Nagios scheduler will go crazy since all the external command have higher priority against checks.
Regards,
Angelo
Regards,
Angelo
