Trying to do some snazzy capacity reporting and not the ones that come with the XI(they are just bad!). Does anyone has any examples or templates of they done with Power BI(or any other reporting/analytical tool?)
Thanks!
Anyone done PowerBI to Nagios integration?
Re: Anyone done PowerBI to Nagios integration?
By the way, we are working hard on making enhancements to the reporting and visuals for XI version 6, so stay tuned!
https://www.nagios.com/roadmaps/
Benjamin
Actually, I haven't come across any integration with Power Bi, but let us know if you're able to set something up.Trying to do some snazzy capacity reporting and not the ones that come with the XI(they are just bad!). Does anyone has any examples or templates of they done with Power BI(or any other reporting/analytical tool?)
Benjamin
I think a common way of reporting capacity etc is to:
Prometheus Node Exported running on each node
Prometheus to collect and store data
Grafana to query Prometheus for data, render in graphs on dashboards
