Hello All,
I am using Nagios Core 4.4.6 and I have a problem with nrpe logging .
So nrpe is logging too much messages in syslog.(on servers that I monitor) Are there possibilities to limit messages like shown below.
Sep 28 09:54:04 vpn-box nrpe[4074885]: Could not read request from client "this is the Nagios core IP address", bailing out...
Sep 28 09:54:04 vpn-box nrpe[4074885]: INFO: SSL Socket Shutdown.
Sep 28 09:54:05 vpn-box nrpe[4074902]: Error: (use_ssl == true): Request packet version was invalid!
Sep 28 09:54:05 vpn-box nrpe[4074902]: Could not read request from client "this is the Nagios core IP address", bailing out...
Sep 28 09:54:05 vpn-box nrpe[4074902]: INFO: SSL Socket Shutdown.
Sep 28 09:54:06 vpn-box nrpe[4074912]: Error: (use_ssl == true): Request packet version was invalid!
Sep 28 09:54:06 vpn-box nrpe[4074912]: Could not read request from client "this is the Nagios core IP address", bailing out...
Sep 28 09:54:06 vpn-box nrpe[4074912]: INFO: SSL Socket Shutdown.
I've checked the log options at /etc/nagios/nrpe.cfg and the only solution I could find was to stop all logging.
# This option allows you to enable or disable logging error messages to the syslog facilities.
# If this option is not set, the error messages will be logged.
disable_syslog=1
NRPE v 4.0.0
Best Regards,
Mladen
nrpe log options and limit the log volume
Re: nrpe log options and limit the log volume
There's a parameter for logging to an nrpe.log or whatever you name it. Maybe try disabling syslog and defining the nrpe log. If it grows a lot don't forget a logrotate for it...
