I am trying to integrate installed ganglia on my caos based system witn nagios on c\same system.
i have changed the nagios.cfg by adding.
cfg_file=/usr/local/nagios/etc/objects/ganglia_service.cfg
nt my ganglia_service.cfg is:
command_name check_ganglia
command_line $USER1$/check_ganglia.py -h $HOSTNAME$ -m $ARG1$ -w $ARG2$ -c $ARG3$
define servicegroup {
servicegroup_name ganglia-metrics
alias Ganglia Metrics
name ganglia-service
hostgroup_name linux-servers
service_groups ganglia-metrics
notifications_enabled 0
use ganglia-service
service_description load_one
check_command check_ganglia!load_one!4!5
use ganglia-service
service_description disk_free
check_command check_ganglia!disk_free!10!5
use ganglia-service
service_description cpu_speed
check_command check_ganglia!cpu_speed!3000!3500
still i am getting erroe in my nagios implementation as:
cpu_speed UNKNOWN 07-05-2010 12:24:36 0d 1h 35m 32s 3/3 CHECKGANGLIA UNKNOWN: Error while getting value "Host/value not found"
disk_free UNKNOWN 07-05-2010 12:30:01 0d 1h 34m 57s 3/3 CHECKGANGLIA UNKNOWN: Error while getting value "Host/value not found"
load_one UNKNOWN 07-05-2010 12:32:41 0d 1h 34m 22s 3/3 CHECKGANGLIA UNKNOWN: Error while getting value "Host/value not found"
DOES SOMEBODY HAVE ANY IDEA??
