(also here, https://support.nagios.com/kb/article/n ... t-599.html)
$ ./send_nrdp.sh -h
send_nrdp.sh Revision 0.6.1 - Send NRDP script for Nagios
<snip>
Directory:
-D /path/to/temp/dir
This is a directory that contains XML files in the format
above. Additionally, if the -d flag is specified, send_nrdp.sh
will create temp files here if the server could not be reached.
On additional calls with the same -D path, if a connection to
the server is successful, all temp files will be sent.
"Additionally, if the -D flag" . . . i.e. uppercase "D"
