Send SNMP traps to remote host on a custom port
Hello, I am using Nagios® Core™ 4.4.2 and working on to send SNMP traps to another host in the same network on port 8436 rather than default 162. The only port open at the destination is 8436. Any help what changes do I need to make in Nagios or VM itself would be much appreciated.
Re: Send SNMP traps to remote host on a custom port
We are also trying to send snmp traps of the hardware issues to a non-default port.
Have you tried to type a colon and then the needed port number right after the chosen hostname / IP address?
Federal University of Campina Grande | research papers online https://domyassignment.pro/
I use the SNMP Trap Sender component in Nagios XI. A little web searching suggests that it should work in core as well. I send traps to custom ports.
https://youtu.be/npxCbySLDWs
https://support.nagios.com/forum/viewto ... =7&t=46573
https://assets.nagios.com/downloads/nag ... ptrap.html
