Different results
rahul2gupta
Different results
Post by rahul2gupta »
We are getting two different results. When we execute a script manually, we are getting expected result where as in UI(Nagios core) is getting different result. Can you please help me on this?
Regards,
Rahul
benjaminsmith
Re: Different results
Post by benjaminsmith »
Hi Rahul,
When you run the command locally, make sure you're logged in as the nagios user (and not root). Do you get the same results in Nagios Core? If so, then it's probably related to the permissions on the plugin.
--Benjamin
rahul2gupta
Hi Benjamin,
I ran the script as a Nagios use and getting expected result. I double checked permission and its all good.
Actually this script is used by two service checks but on one we are getting OK result where as on 2nd one we are getting following error.
Problem encountered logging into WMS RF interface. Error: TelnetLoginPromptFailure
Can you please help us to resolve this
benjaminsmith
Well, that would confirm the permissions are okay, so it looks like an authentication issue. Are you passing the right credentials? If you cannot figure it out, can you PM the script and I'll take a look at it.
--Benjamin
