check http sometimes cant make SSL connection
Nalagios
Post by Nalagios »
I am running this command to check the certificate of a NetApp Appliance:
/usr/lib64/nagios/plugins/check_http -H x.x.x.x -S --sni -C 40,0
The 90% of the time, the result is
SSL OK - Certificate 'localhost' will expire in 329 days on 2022-10-22 10:23 +0200/CEST.
But there are some moments where it alarms (but in the machine is OK):
CRITICAL - Cannot make SSL connection.
I tried a lot of variations of the command (with -S, without -S, --sni, --ssl=1.2+, etc).
Is there something else I could check?
Because I think that the problem is not in the check...
Nalagios
Re: check http sometimes cant make SSL connection
Post by Nalagios »
It was because the appliance to monitor had not enough resources to be monitored properly.
benjaminsmith
Post by benjaminsmith »
Glad you figure this one out, and many thanks for posting the solution.
We'll go ahead and close this one out.
Thank you for participating in the Nagios Community Forum!
