We have again the problem of minitar gemfile conflict I see again this error after update to Logstash 2.1.11 my be a regression? I can i move the minitar 0.6.1 ? I'm waiting for your input, thanks
/usr/local/nagioslogserver/logstash/bin/logstash-plugin list --verbose
Gem::LoadError: You have already activated minitar 0.6.1, but your Gemfile requires minitar 0.5.4. Prepending `bundle exec` to your command may solve this.
setup at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler/runtime.rb:34
each at org/jruby/RubyArray.java:1613
each at /nagioslogserver/logstash/vendor/jruby/lib/ruby/1.9/forwardable.rb:201
setup at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler/runtime.rb:19
setup at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/bundler-1.9.10/lib/bundler.rb:122
setup! at /nagioslogserver/logstash/lib/bootstrap/bundler.rb:64
execute at /usr/local/nagioslogserver/logstash/lib/pluginmanager/list.rb:17
run at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/clamp-0.6.5/lib/clamp/command.rb:67
execute at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/clamp-0.6.5/lib/clamp/subcommand/execution.rb:11
run at /usr/local/nagioslogserver/logstash/vendor/bundle/jruby/1.9/gems/clamp-0.6.5/lib/clamp/command.rb:132
(root) at /usr/local/nagioslogserver/logstash/lib/pluginmanager/main.rb:43
