I am stuck at this point:
Verify Nagflux Is Working
Execute the following query to verify that InfluxDB is being populated with Nagios performance data:
curl -G "http://localhost:8086/query?db=nagflux&pretty=true" --data-urlencode echatspin echatrandom "q=show series
Nagios Core Influxdb
Re: Nagios Core Influxdb
ou don't need another server. I have Nagios Core, InfluxDB, Nagflux, Histou and Grafana working on same machine. And you don't have to uninstal PNP4Nagios, just stop & disable service on boot: systemctl stop npcd.service && systemctl disable npcd.service.
After that you have to edit nagios.cfg o change host_perfdata_file_processing_command value, and change format of *_perfdata_file_template.
Then define process-host-perfdata-file-nagflux & process-service-perfdata-file-nagflux commands in commands.cfg.
If you did like described above omegle.2yu.co , after minute you should see changes in your omeglz echat nagflux database. Install influxdb-client
