Monitor service with brackets in name
Post Reply
hausrocker
Post by hausrocker »
Hi
I would like to monitor a service that is called "myservice (backup)" but the default command
#define service{
#	use			generic-service
#	host_name		MGMT011
#	service_description	Dienst myservice
#	check_command		check_snmp_win!"myservice (backup)"
Does not work.
No services matching myservice (backup) found : CRITICAL
The service name is exactly the display name of the windows service. I suppose the brackets are the problem.
I already found out I could also look for just "myservice" and leave the part with brackets completely away. That works unless there are 2 services that only have different information in brackets:
myservice (Main) and myservice (Backup)
Then the system returns:
2 services active (matching myservice) : WARNING
I have the SNMP Service enabled for user public with read only for the Nagios Server IP.
Any ideas on this?
hausrocker
Re: Monitor service with brackets in name
This forum is obviously dead and should be closed. No support at all.
I found a solution in the mean time. sc config "Old service name" displayname= "New service name" on the Windows system.
Post Reply
