Nagios 3.2.1 installed on OpenSUSE 11.2
1. had nagios set up and GUI running.
2. testing by monitoring a few https host which created from /usr/local/nagios/etc/objects/https.cfg ..... and added parameter cfg_file=/usr/local/nagios/etc/objects/https.cfg into nagios.cfg. Work till here so far so good!
3. Problem starts HERE. trying to split the few host which defined in the https.cfg into afew different files,
eg. httpsCN.cfg, httpsSG.cfg, httpsUS.cfg and etc
Excluded the parameter cfg_file=/usr/local/nagios/etc/objects/https.cfg from nagios.cfg and included new parameter:
cfg_file=/usr/local/nagios/etc/objects/httpsCN.cfg
cfg_file=/usr/local/nagios/etc/objects/httpsSG.cfg
cfg_file=/usr/local/nagios/etc/objects/httpsUS.cfg
After that the nagios GUI @localhost/nagios wont refresh to new host. Instead it keep showing the old https.cfg even though that file isnt pointed in nagios.cfg and the physical file of https.cfg is deleted.
Tried "service nagios reload, restart, stop, start". Tried restart Apache2, clear cache, restart computer. and it still persist with the old host and not the new 1.
Double checked that the cfg_file=/usr/local/nagios/etc/objects/httpsUS.cfg and etc parameter is correctly written.
Please kindly help. Any tips on what i should do?
