i have run the Naclinet++ and the follow error message, i just want know, is this for server problem or clinet problem? how to check these?
2012-12-07 14:46:10: message:modules\FileLogger\FileLogger.cpp:86: Starting to log for: NSClient++ - 0.3.9.327 2011-08-16
2012-12-07 14:46:11: message:CACHENSClient++.cpp:445: Booting: NSClientpp (Nagios) 0.3.9.327 2011-08-16 w32
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Enabling debug mode...
2012-12-07 14:46:11: debug:CACHENSClient++.cpp:557: Attempting to start NSCLient++ - 0.3.9.327 2011-08-16
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: CheckDisk...
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: Event log Checker....
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: Helper function...
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: CheckSystem...
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: CheckWMI...
2012-12-07 14:46:11: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:73: Autodetected w2k or later, using w2k PDH counters.
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: File logger...
2012-12-07 14:46:11: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:110: Using index to retrive counternames
2012-12-07 14:46:11: message:CACHEmodules\FileLogger\FileLogger.cpp:87: Log path is: C:\Program Files\NSClient++\\nsclient.log
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: NRPE server (w/ SSL)...
2012-12-07 14:46:11: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:130: Found countername: CPU: \Processor(_total)\% Processor Time
2012-12-07 14:46:11: debug:CACHEmodules\NRPEListener\NRPEListener.cpp:92: Loading all commands (from NRPE)
2012-12-07 14:46:11: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:131: Found countername: UPTIME: \System\System Up Time
2012-12-07 14:46:11: debug:CACHEmodules\NRPEListener\NRPEListener.cpp:122: Starting NRPE socket...
2012-12-07 14:46:11: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:132: Found countername: MCL: \Memory\Commit Limit
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: NSCAAgent (w/ encryption)...
2012-12-07 14:46:11: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:133: Found countername: MCB: \Memory\Committed Bytes
2012-12-07 14:46:11: error:CACHEd:\source\nscp\branches\stable\include\Socket.h:691: bind failed: 10048: 通常每个套接字地址(协议/网络地址/端口)只允许使用一次。
2012-12-07 14:46:11: debug:CACHEmodules\NSCAAgent\NSCAThread.cpp:77: Time difference for NSCA server is: 0
2012-12-07 14:46:11: error:CACHEd:\source\nscp\branches\stable\include\Socket.h:722: Socket did not start properly, we will now do nothing...
2012-12-07 14:46:11: debug:CACHEmodules\NSCAAgent\NSCAThread.cpp:87: Only reporting: ok,warning,critical,unknown
2012-12-07 14:46:11: debug:CACHEmodules\NSCAAgent\NSCAThread.cpp:119: Autodetected hostname: CFSERVER
2012-12-07 14:46:11: debug:CACHENSClient++.cpp Loading plugin: NSClient server...
2012-12-07 14:46:11: debug:modules\NSCAAgent\NSCAThread.cpp:188: Drifting: 0
2012-12-07 14:46:11: debug:NSClient++.cpp:709: NSCLient++ - 0.3.9.327 2011-08-16 Started!
2012-12-07 14:46:11: error:d:\source\nscp\branches\stable\include\Socket.h:691: bind failed: 10048: 通常每个套接字地址(协议/网络地址/端口)只允许使用一次。
2012-12-07 14:46:11: message:NSClient++.cpp:461: Using settings from: INI-file
2012-12-07 14:46:11: error:d:\source\nscp\branches\stable\include\Socket.h:722: Socket did not start properly, we will now do nothing...
2012-12-07 14:46:11: message:NSClient++.cpp:462: Enter command to inject or exit to terminate...
2012-12-07 14:47:10: debug:modules\NSCAAgent\NSCAThread.cpp:240: Nothing to report, thus not reporting anything...
2012-12-07 14:48:10: debug:modules\NSCAAgent\NSCAThread.cpp:240: Nothing to report, thus not reporting anything...
2012-12-07 14:51:16: message:modules\FileLogger\FileLogger.cpp:86: Starting to log for: NSClient++ - 0.3.9.327 2011-08-16
2012-12-07 14:51:24: message:modules\FileLogger\FileLogger.cpp:86: Starting to log for: NSClient++ - 0.3.9.327 2011-08-16
2012-12-07 14:51:24: message:CACHENSClient++.cpp:445: Booting: NSClientpp (Nagios) 0.3.9.327 2011-08-16 w32
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Enabling debug mode...
2012-12-07 14:51:24: debug:CACHENSClient++.cpp:557: Attempting to start NSCLient++ - 0.3.9.327 2011-08-16
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: CheckDisk...
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: Event log Checker....
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: Helper function...
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: CheckSystem...
2012-12-07 14:51:24: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:73: Autodetected w2k or later, using w2k PDH counters.
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: CheckWMI...
2012-12-07 14:51:24: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:110: Using index to retrive counternames
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: File logger...
2012-12-07 14:51:24: message:CACHEmodules\FileLogger\FileLogger.cpp:87: Log path is: C:\Program Files\NSClient++\\nsclient.log
2012-12-07 14:51:24: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:130: Found countername: CPU: \Processor(_total)\% Processor Time
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: NRPE server (w/ SSL)...
2012-12-07 14:51:24: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:131: Found countername: UPTIME: \System\System Up Time
2012-12-07 14:51:24: debug:CACHEmodules\NRPEListener\NRPEListener.cpp:92: Loading all commands (from NRPE)
2012-12-07 14:51:24: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:132: Found countername: MCL: \Memory\Commit Limit
2012-12-07 14:51:24: debug:CACHEmodules\NRPEListener\NRPEListener.cpp:122: Starting NRPE socket...
2012-12-07 14:51:24: debug:CACHEmodules\CheckSystem\PDHCollector.cpp:133: Found countername: MCB: \Memory\Committed Bytes
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: NSCAAgent (w/ encryption)...
2012-12-07 14:51:24: error:CACHEd:\source\nscp\branches\stable\include\Socket.h:691: bind failed: 10048: 通常每个套接字地址(协议/网络地址/端口)只允许使用一次。
2012-12-07 14:51:24: debug:CACHEmodules\NSCAAgent\NSCAThread.cpp:77: Time difference for NSCA server is: 0
2012-12-07 14:51:24: error:CACHEd:\source\nscp\branches\stable\include\Socket.h:722: Socket did not start properly, we will now do nothing...
2012-12-07 14:51:24: debug:CACHEmodules\NSCAAgent\NSCAThread.cpp:87: Only reporting: ok,warning,critical,unknown
2012-12-07 14:51:24: debug:CACHEmodules\NSCAAgent\NSCAThread.cpp:119: Autodetected hostname: CFSERVER
2012-12-07 14:51:24: debug:CACHENSClient++.cpp Loading plugin: NSClient server...
2012-12-07 14:51:24: debug:modules\NSCAAgent\NSCAThread.cpp:188: Drifting: 0
2012-12-07 14:51:24: debug:NSClient++.cpp:709: NSCLient++ - 0.3.9.327 2011-08-16 Started!
2012-12-07 14:51:24: error:d:\source\nscp\branches\stable\include\Socket.h:691: bind failed: 10048: 通常每个套接字地址(协议/网络地址/端口)只允许使用一次。
2012-12-07 14:51:24: message:NSClient++.cpp:461: Using settings from: INI-file
2012-12-07 14:51:24: error:d:\source\nscp\branches\stable\include\Socket.h:722: Socket did not start properly, we will now do nothing...
2012-12-07 14:51:24: message:NSClient++.cpp:462: Enter command to inject or exit to terminate...
2012-12-07 14:52:24: debug:modules\NSCAAgent\NSCAThread.cpp:240: Nothing to report, thus not reporting anything...
2012-12-07 14:53:24: debug:modules\NSCAAgent\NSCAThread.cpp:240: Nothing to report, thus not reporting anything...
2012-12-07 14:54:24: debug:modules\NSCAAgent\NSCAThread.cpp:240: Nothing to report, thus not reporting anything...
Error message for Naclinet++
Re: Error message for Naclinet++
This seems to be a port related issue, check to see if you have multiple instances of NSClient++ running, or something using it's port.
