check_nrpe CheckWMIValue Performance Data Help
effextc
Post by effextc »
Hey everyone! I've got a problem that I've been banging my head against the wall about. I'm trying to pull in performance data using "check_nrpe CheckWMIValue" and I'm getting no where.
I've got a pretty standard Nagios install. Ubuntu 10.04, Nagios 3.2.2, Plugins 1.4.15, NRPE 2.12, MRTG, NSClient++ 0.3.8, and NagiosGraph.
My command.cfg looks like this:
# 'check_nrpe' command definition
        command_name    check_nrpe
        command_line    $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
My service definition looks like this:
        use generic-service;
        host_name 172.28.200.7
        service_description     C Drive Read IO;
        check_command   check_nrpe!CheckWMIValue -a "Query=Select Name, DiskReadsPersec from Win32_PerfFormattedData_PerfDisk_PhysicalDisk WHERE Name like \'%C:%\'"  Check:DiskReads=DiskReadsPersec MaxWarn=0 MaxCrit=100 AliasCol=Name;
        action_url      /nagios/cgi-bin/show.cgi?host=$HOSTNAME$&service=$SERVICEDESC$' onMouseOver='showGraphPopup(this)' onMouseOut='hideGraphPopup()' rel='/nagios$;
WIth that, all I get in Nagios is:
Status Information:	OK: Everything seems fine.
Performance Data:
The performance data is blank. If run check_nrpe from the command line with the arguments listed above, I get:
OK: Everything seems fine.|'DiskReads'=0;0;100;
When Nagios builds the macro, it looks like it processes fine. Below is the Nagios.debug:
1285383893.989261] [2320.2] [pid=756] Raw Command Input: $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
[1285383894.205646] [2320.2] [pid=756] Expanded Command Output: $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
[1285383894.205665] [2048.1] [pid=756] Processing: '$USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$'
[1285383894.205830] [2048.2] [pid=756]   Processing part: '/check_nrpe -H '
[1285383894.205839] [2048.2] [pid=756]   Not currently in macro.  Running output (40): '/usr/local/nagios/libexec/check_nrpe -H '
[1285383894.205917] [2048.2] [pid=756]   Uncleaned macro.  Running output (52): '/usr/local/nagios/libexec/check_nrpe -H 172.28.200.7'
[1285383894.205926] [2048.2] [pid=756]   Just finished macro.  Running output (52): '/usr/local/nagios/libexec/check_nrpe -H 172.28.200.7'
[1285383894.205943] [2048.2] [pid=756]   Not currently in macro.  Running output (56): '/usr/local/nagios/libexec/check_nrpe -H 172.28.200.7 -c '
[1285383894.205986] [2048.2] [pid=756]   Uncleaned macro.  Running output (251): '/usr/local/nagios/libexec/check_nrpe -H 172.28.200.7 -c CheckWMIValue -a "Query=Select Name, DiskReadsPersec from Win32_PerfFormattedData_PerfDisk_PhysicalDisk WHERE Name like '%C:%'" Check:DiskReads=DiskReadsPersec MaxWarn=0 MaxCrit=100 AliasCol=Name'
[1285383894.205995] [2048.2] [pid=756]   Just finished macro.  Running output (251): '/usr/local/nagios/libexec/check_nrpe -H 172.28.200.7 -c CheckWMIValue -a "Query=Select Name, DiskReadsPersec from Win32_PerfFormattedData_PerfDisk_PhysicalDisk WHERE Name like '%C:%'" Check:DiskReads=DiskReadsPersec MaxWarn=0 MaxCrit=100 AliasCol=Name'
[1285383894.206012] [2048.2] [pid=756]   Not currently in macro.  Running output (251): '/usr/local/nagios/libexec/check_nrpe -H 172.28.200.7 -c CheckWMIValue -a "Query=Select Name, DiskReadsPersec from Win32_PerfFormattedData_PerfDisk_PhysicalDisk WHERE Name like '%C:%'" Check:DiskReads=DiskReadsPersec MaxWarn=0 MaxCrit=100 AliasCol=Name'
[1285383894.206021] [2048.1] [pid=756]   Done.  Final output: '/usr/local/nagios/libexec/check_nrpe -H 172.28.200.7 -c CheckWMIValue -a "Query=Select Name, DiskReadsPersec from Win32_PerfFormattedData_PerfDisk_PhysicalDisk WHERE Name like '%C:%'" Check:DiskReads=DiskReadsPersec MaxWarn=0 MaxCrit=100 AliasCol=Name'
The Service Check Debug looks like this:
[1285383976.395533] [016.0] [pid=756] Scheduling a forced, active check of service 'C Drive Read IO' on host '172.28.200.7' @ Fri Sep 24 23:06:14 2010
[1285383976.646106] [016.0] [pid=756] Attempting to run scheduled check of service 'C Drive Read IO' on host '172.28.200.7': check options=1, latency=2.646000
[1285383976.646188] [016.0] [pid=756] Checking service 'C Drive Read IO' on host '172.28.200.7'...
[1285383982.108064] [016.1] [pid=756] Handling check result for service 'C Drive Read IO' on host '172.28.200.7'...
[1285383982.108073] [016.0] [pid=756] ** Handling check result for service 'C Drive Read IO' on host '172.28.200.7'...
[1285383982.108081] [016.1] [pid=756] HOST: 172.28.200.7, SERVICE: C Drive Read IO, CHECK TYPE: Active, OPTIONS: 1, SCHEDULED: Yes, RESCHEDULE: Yes, EXITED OK: Yes, RETURN CODE: 0, OUTPUT: OK: Everything seems fine.\n
[1285383982.108191] [016.0] [pid=756] Scheduling a non-forced, active check of service 'C Drive Read IO' on host '172.28.200.7' @ Fri Sep 24 23:16:16 2010
[1285383982.108227] [016.1] [pid=756] Checking service 'C Drive Read IO' on host '172.28.200.7' for flapping...
[1285383982.108255] [016.1] [pid=756] Checking host '172.28.200.7' for flapping...
[1285383982.108348] [016.2] [pid=756] Processed service performance data file output: 1285383976||172.28.200.7||C Drive Read IO||OK: Everything seems fine.||
I'm completely lost!!!! It looks like it's processing the macros correctly. If I run check_nrpe with the arguments in the command line it works correctly. It's just when Nagios processes the command it doesn't receive the performance data. It's like it's dropping the end of completely. I know if you omit the MinCrit and MaxCrit it won't display the performance data but I have those in there. The macro processing even keeps it. It just seems like when Nagios executes the command, it drops them or something. Does anyone have any thoughts?
Thanks in advance everyone!
