Help Needed
likith_jogi
Help Needed
Post by likith_jogi »
Hi guys,
i'm new to nagios,
i hv installed nagios from rpm package, but i'm getting the follwing error, plz help me
Return code of 126 is out of bounds - plugin may be missing
regards,
Likith Jogi
mguthrie
Re: Help Needed
Post by mguthrie »
This is usually from a misconfiguration with the check command. The plugin may not be installed, or it may not be defined as a check command in the commands.cfg file yet. If it is already defined, try manually running your check from the command line to check and make sure you you've got your settings correct.
cd /usr/local/nagios/libexec
./check_<something> <options>
