Deactivated Hosts Aren't Removed from Core
Re: Deactivated Hosts Aren't Removed from Core
Fix has been applied to the XI 2014 TRUNK and is undergoing testing.
Hossy
Post by Hossy »
scottwilkerson wrote:Now I understand what you are saying.
I will add this to our internal TODO, I believe I know how we can accomplish it, but it will be a major change that will require significant testing...
Thanks, Scott. When you have it, could you give me a bug ID or some identifier to (quickly) ask about the status of the fix in the future?
I don't have a "bug ID", but it will be in 2014. However the changes were pretty straight forward, if you want I will attach what needs to be changed here to apply to a 2012 install if you would like to test it...
Install this CCM through Admin -> Manage Components
ccm.zip
unzip this file and place in /usr/local/nagiosxi/scripts
nagiosql_exportall.zip
Hossy
Post by Hossy »
scottwilkerson wrote:I don't have a "bug ID", but it will be in 2014. However the changes were pretty straight forward, if you want I will attach what needs to be changed here to apply to a 2012 install if you would like to test it...
ccm.zip
Is this a replacement for your earlier ccm.zip or in addition?
Is there a way to rollback the changes if it fails or doesn't fix the problem? (I haven't messed with Manage Components yet)
EDIT: We're running Nagios XI 2012R1.8
Yes, it is a replacement.
Yes. You can install the previous ccm component by going to Admin->Manage Components->Browse...->Upload Component
Hossy
Post by Hossy »
lmiltchev wrote:Yes. You can install the previous ccm component by going to Admin->Manage Components->Browse...->Upload Component
Where do I get the current ccm? I presume there's a way to download it from XI? or is it stored on the file system somewhere?
EDIT: Under Manage Components, there's no download link for CCM like there are on others.
If you installed the ccm.zip that was provided by scottwilkerson (Tue Jan 28, 2014 1:17 pm; page 2), you can re-download it and install it.
If you haven't installed it but you want to save the current ccm, you can probably zip all of the files in the "/usr/local/nagiosxi/html/includes/components/ccm" directory as "ccm.zip", and install it later if you need to.
Hossy
Post by Hossy »
lmiltchev wrote:If you installed the ccm.zip that was provided by scottwilkerson (Tue Jan 28, 2014 1:17 pm; page 2), you can re-download it and install it.
Ah, ok. So the ZIP file is just a copy of the /usr/local/nagiosxi/html/includes/components/ccm directory. Sure, I just zip that up before testing the new ccm.zip. Thanks for the info!
I'm presuming the second ZIP file fixes the Apply Configuration issue (the second issue listed)?
Hossy wrote:Ah, ok. So the ZIP file is just a copy of the /usr/local/nagiosxi/html/includes/components/ccm directory. Sure, I just zip that up before testing the new ccm.zip
perfect
Hossy wrote: I'm presuming the second ZIP file fixes the Apply Configuration issue (the second issue listed)?
Correct, actually, they both do..
Hossy
Post by Hossy »
ccm.zip
Unfortunately, this didn't fix the problem. I was still able to deactivate a host that I know would cause an invalid config. And, upon fixing the error after running Apply Configuration, the deactivated host CFG file was never deleted.
EDIT: I deactivated two hosts. One through the checkbox/list method and one through clicking on the host and unchecking the Active checkbox.
