Critico Active Directory 02 TEA (AD02_TEA_CRIT)
Sanidad Active Directory 02 TEA (AD02_TEA_SAN)
Can't configure Servicegroup BPI
Re: Can't configure Servicegroup BPI
Ok, bug confirmed. I've got it recreated locally now and we'll take a look at getting that fixed ASAP.
Ok, so we've fixed the issue in SVN for the next release of XI (1.8+). It appears there as a bug in the hostgroup/servicegroup sync that was creating duplicate definitions for the hostgroups and servicegroups in BPI. This is what was preventing the group from being edited afterwards. Here's the hotfix for this issue.
Open the BPI config by clicking the "Manually Edit Config" link, and locate your servicegroup BPI definitions. Clear out all existing servicegroup definitions in this file. Save the BPI config file.
Download and replace the following file with the one attached:
/usr/local/nagiosxi/html/includes/components/nagiosbpi/functions/bpi_page_router.php
Once the file is updated you should be able to resync the servicegroups and edit them as expected.
mauricio.moya
Thanks a lot!
Now is working ok. bag solved!
