EDIT: I reverted to the snapshot I took prior so this is no longer an issue for now. This arose trying to get my hostname set in all the proper places. I got it to where I was seeing the desired outputs outlined here: http://cbl.abuseat.org/hostname.html but caused the DB connection error.
[root@localhost ~]# psql nagiosxi nagiosxi
psql (8.4.12)
Type "help" for help.
nagiosxi=> VACUUM ANALYZE;
WARNING: skipping "pg_database" --- only superuser can vacuum it
WARNING: skipping "pg_authid" --- only superuser can vacuum it
WARNING: skipping "pg_tablespace" --- only superuser can vacuum it
WARNING: skipping "pg_pltemplate" --- only superuser can vacuum it
WARNING: skipping "pg_shdepend" --- only superuser can vacuum it
WARNING: skipping "pg_shdescription" --- only superuser can vacuum it
WARNING: skipping "pg_auth_members" --- only superuser can vacuum it
VACUUM
nagiosxi=> su
nagiosxi-> VACUUM ANALYZE;
ERROR: syntax error at or near "su"
LINE 1: su
nagiosxi=> VACUUM FULL;
VACUUM
Last edited by mobiledataforce on Thu Apr 25, 2013 12:54 pm, edited 2 times in total.
The "skipping" errors are WAI. They can be ignored. Just proceed with the rest of the commands for the full vacuum.
