Deleting Recurring Downtime Doesn't Work
Re: Deleting Recurring Downtime Doesn't Work
Yes, it is there
Thanks for pointing it.
But there is another question stay open:
Why it add already added services?
For example there is Service Group A. In this service group is services AB, AC, AD
I did Recurring Downtime for Servicegroup A for every monday at 2AM.
I can see this in Scheduled Downtime->Scheduled Service Downtime, everything is fine.
After 1 hours I see that is another additional downtimed services AB,AC,AD with different "Entry Time" but for same "Start Time End Time Type Duration".
Regards,
Regards,
You can overlap downtime, as dictated by the Scheduled Downtime section in:
http://nagios.sourceforge.net/docs/3_0/downtime.html
It says:
It says:
I believe this is what you are referring to correct? If not I apologize.If you schedule overlapping periods of downtime for a host or service (in this case the periods were 7:40pm-9:30pm and 9:20pm-1:30am), Nagios will wait until the last period of scheduled downtime is over before it allows notifications to be sent out for that host or service. In this example notifications would be suppressed for host A until 1:30am Tuesday morning.
No, I did not adding anything additional.
I do just Recurring Downtime for Service Group.
First look - fine.
But after hours the same services coming in again and again.
I can try to add it now and next time will provide the screen shot.
First look - fine.
A picture is worth a thousand words.
Thanks!
Please see attached screen shot
I think I found issue in /usr/local/nagiosxi/cron/recurringdowntime.pl.
I did changes in.
Because in
in here:
it has following output:
It has ";" instead of ":"
But in readdowntime2 it add following string:
Here is my readdowntime2 sub (the bold is my changes):
I did changes in
sub readdowntime2 Because in
sub schedule_servicegroup($$$$$$) {Code: Select all
foreach $sr ( @{$servicegroups{$sg}} ) {
print "$sr:$s\n";
Scheduling servicegroup Prod_SC_CitrixFarm
SQ5VPMXENAPP003;Citrix_App_MetaFRAME_Load_Level:1368683940
SQ5VPMXENAPP003:Citrix_App_MetaFRAME_Load_Level:1368683940Here is my readdowntime2 sub (the bold is my changes):
sub readdowntime2 {
my($hd,$sd,$start,$a);
my($f) = $DOWNDAT;
my($dtid);
$f = $STATUSDAT if(!$f or ! -r $f);
$f = $RETENTIONDAT if(!$f or ! -r $f);
if(!$f or ! -r $f) { readdowntime; return; }
print "Reading downtime information from $f ..." if($DEBUG);
$a = 0;
open DD, "<$f" or return;
while ( <DD> ) {
if( /^\s*hostdowntime/ ) {
$a = 1; $hd = $dtid = ""; $start = 0;
print "Hostdowntime found\n";
} elsif( /^\s*servicedowntime/ ) {
$a = 2; $hd = $sd = $dtid = ""; $start = 0;
print "Servicedowntime found\n";
} elsif( $a and /^\s*}/ ) {
if($a == 1) {
$downtime{"$hd:$start"} = 1;
print "Adding host $hd:$start:$dtid\n" if($DEBUG);
} elsif($a == 2) {
$downtime{"$hd;$sd:$start"} = 1; # here I made changes, instead of ":" I added ";"
#$downtime{"$hd:$sd:$start"} = 1;
print "Adding service $hd:$sd:$start:$dtid\n" if($DEBUG);
$a = 0;
} elsif( $a ) {
if( /^\s*host_name\s*=\s*(.*\S)/ ) { $hd = $1; }
elsif( /^\s*service_description\s*=\s*(.*\S)/ ) { $sd = $1; }
elsif( /^\s*start_time\s*=\s*(\d+)/ ) { $start = $1; }
elsif( /^\s*downtime_id\s*=\s*(\d+)/ ) { $dtid = $1; }
close DD;
print "Done.\n" if($DEBUG);
}Re: Deleting Recurring Downtime Doesn't Work
So, additional information.
I found following.
Some how in this variable "@{$servicegroups{$sg}}" the collect services twice from the same service group.
I did couple of changes, will provide script tomorrow after testing.
Update:
Here is diff that i did:
I found following.
Update:
[root@sq5vplnagios001 ~]# diff -u /usr/local/nagiosxi/cron/recurringdowntime.pl.orig /usr/local/nagiosxi/cron/recurringdowntime.pl
--- /usr/local/nagiosxi/cron/recurringdowntime.pl.orig 2013-04-20 12:05:18.000000000 -0400
+++ /usr/local/nagiosxi/cron/recurringdowntime.pl 2013-05-14 22:47:08.000000000 -0400
@@ -195,6 +195,7 @@
sub readdowntime2 {
my($f) = $DOWNDAT;
+ my($dtid);
@@ -203,22 +204,25 @@
while ( <DD> ) {
- $a = 1; $hd = ""; $start = 0;
+ $a = 1; $hd = $dtid = ""; $start = 0;
+ print "Hostdowntime found\n";
- $a = 2; $hd = $sd = ""; $start = 0;
+ $a = 2; $hd = $sd = $dtid = ""; $start = 0;
+ print "Servicedowntime found\n";
if($a == 1) {
- print "Adding $hd:$start\n" if($DEBUG);
+ print "Adding host $hd:$start:$dtid\n" if($DEBUG);
} elsif($a == 2) {
- $downtime{"$hd:$sd:$start"} = 1;
- print "Adding $hd:$sd:$start\n" if($DEBUG);
+ $downtime{"$hd;$sd:$start"} = 1;
+ print "Adding service $hd:$sd:$start:$dtid\n" if($DEBUG);
$a = 0;
} elsif( $a ) {
+ elsif( /^\s*downtime_id\s*=\s*(\d+)/ ) { $dtid = $1; }
close DD;
@@ -257,6 +261,7 @@
return $rv;
sub schedule_service($$$$$$) {
+ print "chedule_service\n";
my($h,$svc,$s,$d,$u,$c) = @_;
my($rv);
$u = "Automatic" if(!$u);
@@ -314,6 +319,9 @@
return $rv;
+#schedule_servicegroup($sref->{servicegroup_name} ,$next,$sref->{duration},$sref->{user},$sref->{comment},$sref->{svcalso});
+# sg s d u c sa
+ print "chedule_servicegroup\n";
my($sg,$s,$d,$u,$c,$sa) = @_;
my($rv,$sr);
@@ -325,11 +333,26 @@
print "Scheduling servicegroup $sg\n" if($DEBUG);
$rv = 0;
return "Servicegroup $sg not recognised!" if(!defined $servicegroups{$sg}) ;
+ print @{$servicegroups{$sg}};
+ print "\n";
+ print "$sr:$s - ";
+ my $test_v = $downtime{"$sr:$s"};
+ print "$test_v\n";
+ print "sa - $sa\n";
+ #my @test_v = %downtime;
+ #print "@test_v";
if( !defined $downtime{"$sr:$s"} ) {
# $rv = sendcmd "SCHEDULE_SVC_DOWNTIME;$sr;$s;".($s+($d*60)).";1;0;$u;$c";
$rv = sendcmd "SCHEDULE_SVC_DOWNTIME;$sr;$s;".($s+($d*60)).";1;0;".($d*60).";$u;$c";
+ if (!$rv){
+ print "Adding added downtime";
+ $downtime{"$sr:$s"} = 1;
+ print "rv - $rv";
if($sa) {
+ print "if sa";
# $rv = sendcmd "SCHEDULE_SVC_DOWNTIME;$sr;$s;".($s+($d*60)).";1;0;$u;$c" if(!$rv);
$rv = sendcmd "SCHEDULE_SVC_DOWNTIME;$sr;$s;".($s+($d*60)).";1;0;".($d*60).";$u;$c" if(!$rv);
@@ -380,8 +403,10 @@
close CFG;
+ print "@schedules\n";
return 0;
sub numerically { $a<=>$b; }
my %dow = ( mon=>1, tue=>2, wed=>3, thu=>4, fri=>5, sat=>6, sun=>0 );
sub parse_days($) {
@@ -409,9 +434,11 @@
# Identify 'now'.
@lt = localtime($T);
($dow,$h,$min,$d,$m,$y) = ($lt[6],$lt[2],$lt[1],$lt[3],$lt[4],$lt[5]);
-print "\n now: $dow,$h,$min,$d,$m,$y \n";
+ print "\n now: $dow,$h,$min,$d,$m,$y \n";
# Loop through all known schedules, find their next due time
foreach $sref ( @schedules ) {
+ print "Loop through all known schedules, find their next due time";
+ print "$sref\n";
if($DEBUG) {
if(defined $sref->{comment}) {
print $sref->{comment} .": ";
Thanks. Let us know.
Interesting, how are the changes working out for you?
Perfect.
it works us expected - no any doubled services from Recc Down timed service group.
Of course - most of added line is for debug purposes.
This issue happened when we have migrated from 2011 to 2012 version.
In 2011 everything was fine, without any issues.
Regards,
Regards,
