Windows Service names with spaces fail to parse correctly
Re: Windows Service names with spaces fail to parse correctl
Sorry for the delay. I tried the change that was recommended.
What exactly did you try? Did you try the following?
Try changing the following line in the NSC.ini (or nsclient.ini) from this:
runcmd=scripts\runcmd.bat $ARG1
to this:
runcmd=scripts\runcmd.bat "$ARG1$"
Restart the nsclinet++ service and run a check from the nagios server:
./check_nrpe -H 192.168.5.180 -p 5666 -c runcmd -a 'Klocwork 9.2 Server'
Did this fail? Any feedback on this?
It seems like that we are shifting the focus from restarting a windows service to troubleshooting custom powershell scripts...
intelXIadmin
Post by intelXIadmin »
This is solved. No matter what we tried, it doesn't seem to work with spaces. I had the Service renamed.
Post by slansing »
That is very strange, it is working as expected in other environments. Thanks for letting us know what the resolution was.
