Problem with a check
abrist
Red Shirt
Re: Problem with a check
Post by abrist »
Could run the command from XI with the "--debug" option?
COMMAND: /usr/local/nagios/libexec/tsmmonitor.sh --debug -s=TSMLM1 scratch
How did you create this check in XI? Did you follow the following document?
http://assets.nagios.com/downloads/nagiosxi/docs/Managing_Plugins_in_Nagios_XI.pdf
Can you post the service and command definitions?
guppy_rules
Post by guppy_rules »
Debug gives nothing because the command and the script works well. When I give user apache the proper rights, then the test command from nagiosxi wil work:
But the checks still give an Unknown.
The check command is defined as:
host_name TSM server
service_description Scratch tapes
use xiwizard_linuxserver_ping_service
check_command check_tsm!-s=TSMLM1 scratch!!!!!!!
max_check_attempts 5
check_interval 60
retry_interval 1
notification_interval 60
first_notification_delay 0
notifications_enabled 0
contacts dve015
_xiwizard aix
register 1
The command:
command_name check_tsm
command_line $USER1$/tsmmonitor.sh $ARG1$ $ARG2$ $ARG3$ $ARG4$
Did running the "chown nagios.nagios /usr/local/nagios/libexec/tsmmonitor.sh", as suggested by sreinhardt fix your problem?
guppy_rules
No, unfortunately not:
# ls -l tsmmonitor.sh
-rwxr-xr-x 1 nagios nagios 59319 May 14 14:26 tsmmonitor.sh
abrist
Red Shirt
Post by abrist »
We may need to move this to out ticketing system so that we can set up a remote session if that is possible. Send an email to [email protected]
guppy_rules
I send an email to support.
Post by slansing »
Closing, moving to email support.
