Below are the output of the Command:
[root@nagios155 ~]# service postgresql status
postmaster (pid 29807 23748 20412 20411 19848 19789 19779 19778 19319 19318 19317 19316 18659 11457 10504 6166 5939 5938 5937 5935 5933 5147 5140 5128 3943 3901 3900 3855) is running...
[root@nagios155 ~]# df -h
/dev/mapper/VolGroup00-LogVol00
72G 16G 53G 24% /
/dev/sda1 99M 13M 81M 14% /boot
tmpfs 2.0G 0 2.0G 0% /dev/shm
[root@nagios155 ~]# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
19431424 254463 19176961 2% /
/dev/sda1 26104 35 26069 1% /boot
tmpfs 505450 1 505449 1% /dev/shm
[root@nagios155 ~]# ls -l /usr/local/nagiosxi/scripts/nagiosql.*
-rw-r--r-- 1 root root 153 May 9 15:35 /usr/local/nagiosxi/scripts/nagiosql.cookies
-rw-r--r-- 1 root root 7400 May 9 15:38 /usr/local/nagiosxi/scripts/nagiosql.export.additional
-rw-r--r-- 1 root root 7096 May 9 15:38 /usr/local/nagiosxi/scripts/nagiosql.export.monitoring
-rw-r--r-- 1 root root 383461 May 9 15:35 /usr/local/nagiosxi/scripts/nagiosql.import.monitoring
-rw-r--r-- 1 root root 5286 May 9 15:35 /usr/local/nagiosxi/scripts/nagiosql.login
