yancy wrote:Randy,
Thanks for the feedback, the component and the document should have a quick way to verify connection. I'll add that to the feature request for this component.
the username in nagios should be the same as the user login in AD.
from AD:
right click user > properties > account > "user login name"
-YAncy
Help on LDAPS integration
intelXIadmin
Re: Help on LDAPS integration
Thank you for the help below. That worked. I am now able to authenticate, though, strangely I told the component I don't want TLS or SSL!
