Changing email to when starting downtime
sreinhardt
-fno-stack-protector
Re: Changing email to when starting downtime
Post by sreinhardt »
There is a key difference in the Use definition. This is inheriting those settings from a template, in the case of nagiosadmin generic-contact. These settings should already be applied, however if you do choose to define them for nagiosadmin it will overwrite anything for that same setting applied via the template.
vivithemage
Post by vivithemage »
Ah, and where is the template? Is that:
/usr/local/nagios/etc/objects/templates.cfg
which is default:
define contact{
        name                            generic-contact         ; The name of this contact template
        service_notification_period     24x7                    ; service notifications can be sent anytime
        host_notification_period        24x7                    ; host notifications can be sent anytime
        service_notification_options    w,u,c,r,f,s             ; send notifications for all service states, flapping events, and scheduled downtime events
        host_notification_options       d,u,r,f,s               ; send notifications for all host states, flapping events, and scheduled downtime events
        service_notification_commands   notify-service-by-email ; send service notifications via email
        host_notification_commands      notify-host-by-email    ; send host notifications via email
        register                        0                       ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL CONTACT, JUST A TEMPLATE!
so I could just add this to my contact file:
/usr/local/nagios/etc/objects/contacts.cfg
        service_notification_options    w,u,c,r,f            ; send notifications for all service states, flapping events, and scheduled downtime events
        host_notification_options       d,u,r,f               ; send notifications for all host states, flapping events, and scheduled downtime events
and then create my new contact with only:
define contact {
                contact_name                          downtimealerts
                alias                                 downtimealerts
                service_notification_options    s            ; send notifications for all service states, flapping events, and scheduled downtime events
                host_notification_options       s               ; send notifications for all host states, flapping events, and scheduled downtime events
                email                                 [email protected]
                host_notification_period              none
                service_notification_period           none
Where are the services/monitored sites configuration I should add these to? Assuming this setup is accurate in my ocntacts.cfg?
Post by slansing »
Lets just clear up one point, are you running Nagios Core or Nagios XI? Your other thread refers to NDO2DB and MySql. Just want to make sure you are not trying to edit the flat .cfg files if you are using XI, rather than the interface.
vivithemage
It loos like we are running core...
Nagios® Core™ 3.4.1 I found the ndo2db service, it was stopped, and installed in a non standard folder, and thus had no /etc/init.d/ startup script.
Post by slansing »
You could add:
To contacts in your contacts.cfg file, it will do as sreinhardt pointed out above. You do not need to use the template's options if you do not choose. Contact's will use their notification options, but you should set the same options for your services/hosts in their .cfg files. These files are typically in /usr/local/nagios/etc/hosts and /services.
vivithemage
slansing wrote:You could add:
Yeah, that is what I posted...just add those lines to my nagios contact currently. Then add the one I listed above, and add it to the cfg files for the services/hosts and it should be good.
Post by slansing »
Yes...you were asking if you could do that.. let us know if you need further help.
