Duplicate scheduled downtime after configuring a ram disk
cloberjewels
Re: Duplicate scheduled downtime after configuring a ram dis
Correct. Screenshots uploaded.
We noticed that you are using Nagios XI 2011R3.2. There was a bug with recurring downtime that is fixed in our latest release. I would recommend upgrading your Nagios XI to 2012R2.1.
cloberjewels
Can you provide more details on the bug? Are the symptoms we are experiencing seem related?
We have been running Nagios XI 2011R3.2 for about a year now with no issues. We do plan on upgrading at some point but I would like to be sure upgrading will solve the problem.
The bugs, along with other changes can be found in the changelogs:
These are the 2011 changes alone - http://assets.nagios.com/downloads/nagi ... S-2011.TXT
And the 2012 changes - http://assets.nagios.com/downloads/nagi ... S-2012.TXT
cloberjewels
The changelog does not specify the extent of the bug. Can you confirm from our screen shots that this issue would be resolved by upgrading?
Also, as I stated, I found that the issue appears to be more related to Recurring Downtime. It's scheduling the same downtime multiple times. How does the Recurring Downtime schedule downtime? Is it just running to frequently or not updating a file saying it's been scheduled?
I believe this may have been one of the misc fixes in 2011R2.3, regardless, there are more than enough bug fixes "around a year," and feature additions to warrant an upgrade at this point so this is what we would recommend.
cloberjewels
Here is the solution:
The document http://assets.nagios.com/downloads/nagi ... giosXI.pdf needs to be updated to include editing
/usr/local/nagiosxi/cron/recurringdowntime.pl
and change
= ('','/usr/local/nagios/var/status.dat','','','','');
to
= ('','/var/nagiosramdisk/status.dat','','','','');
It takes several days for the status.dat file to catch up again but that is the fix.
and change
to
Thanks for pointing this out! I will be updating the "Utilizing A RAM Disk In NagiosXI" document as soon as I can.
Instead of updating the document, we are updating /usr/local/nagiosxi/cron/recurringdowntime.pl to read out of the nagios.cfg This will take affect in 2012R2.3
If you need the file before that I am attaching it to this post, unzip and place in /usr/local/nagiosxi/cron/recurringdowntime.pl
