It seems like the problem is caused by "stratum=0". You can read more on the issue here:
http://serverfault.com/questions/269701 ... rding-peer
Try running the check against a remote NTP server (not localhost), and see if the plugin would work fine:
[root@testbox libexec]# ./check_ntp_time -v -H pool.ntp.org
sending request to peer 0
response from peer 0: offset 0.004180928168
response from peer 0: offset 0.00260892103
response from peer 0: offset 0.002613890916
response from peer 0: offset 0.008024519484
sending request to peer 1
response from peer 1: offset -0.00406507263
response from peer 1: offset -0.001290791028
response from peer 1: offset -0.000941132661
response from peer 1: offset 0.001547022199
sending request to peer 2
response from peer 2: offset -0.002509119629
response from peer 2: offset -0.003943699296
response from peer 2: offset -0.00142720103
response from peer 2: offset -0.00291433325
sending request to peer 3
response from peer 3: offset -0.003663558164
response from peer 3: offset -0.003243627492
response from peer 3: offset -0.004003834503
response from peer 3: offset -0.003916329471
overall average offset: 0.004180928168
NTP OK: Offset 0.004180928168 secs|offset=0.004181s;60.000000;120.000000;
The check works fine for me, even if I run it against localhost:
[root@testbox libexec]# ./check_ntp_time -v -H localhost
response from peer 0: offset -3.900611773e-06
response from peer 0: offset -4.698173143e-06
response from peer 0: offset -4.380010068e-06
response from peer 0: offset -4.218425602e-06
response from peer 1: offset -2.949498594e-06
response from peer 1: offset -4.584901035e-06
response from peer 1: offset -4.504807293e-06
response from peer 1: offset -4.11097426e-06
overall average offset: -3.900611773e-06
NTP OK: Offset -3.900611773e-06 secs|offset=-0.000004s;60.000000;120.000000;
...but I don't get "stratum=0" in the output.
For more info, you can probably email
[email protected].
Hope this helps.
