Thank you so much... Trying it now.
One thing though, in the command_line portion I called it as check_procs because I'm still using the same check file (check_procs) as before I'm just using different options on it than is currently defined under the actual check_local_procs one.
But thanks again... Will hopefully let you know soon if it works.
*SOLVED*check_procs says user doesn't exist. Works manually
Re: check_procs says user doesn't exist. Works manually
Oh wait... Never mind. I see what you did. In the command_line it still is check_procs. But once that's done the command always needs to be called as check_user_procs. Sorry
No problem, let us know how it turns out.
I'm now getting this...
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
/var/log/messages on remote host contained this.
Jun 13 14:40:16 nagiostest xinetd[1467]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Jun 13 14:40:16 nagiostest xinetd[1467]: Started working: 1 available service
Jun 13 14:43:59 nagiostest xinetd[1467]: START: nrpe pid=1472 from=::ffff:10.11.12.49
Jun 13 14:43:59 nagiostest nrpe[1472]: INFO: SSL/TLS initialized. All network traffic will be encrypted.
Jun 13 14:43:59 nagiostest nrpe[1472]: Error: Request contained command arguments!
Jun 13 14:43:59 nagiostest nrpe[1472]: Client request was invalid, bailing out...
Jun 13 14:43:59 nagiostest xinetd[1467]: EXIT: nrpe status=0 pid=1472 duration=0(sec)
which kind of confuses me because I have dont_blame_nrpe set to 1.
However, it is a different error message than before.
Could it be because the only command I have setup as check_user_procs is with nrpe? Do I need to setup a command for check_user_procs that does NOT have the NRPE part in there? Or is that not needed.
Did you restart nrpe after making that change? (run all of these commands on the remote host)
Are you loading a different config file?
is there more than one config?
service xinetd restartCode: Select all
ps -aef | grep nrpeCode: Select all
find / -name nrpe.cfgFormer Nagios employee
GOT IT!!!! NRPE wasn't compiled with --enable-command-args
Thank you so much for your help though. i honestly wouldn't have gotten it without your help.
My issue is definitely resolved now. Thanks again...
sreinhardt
- -fno-stack-protector
Re: *SOLVED*check_procs says user doesn't exist. Works manua
Awesome! Thanks for letting us know!
