Bandwidth usage
Re: Bandwidth usage
Can you tell us what version of the Bandwidth Usage Report you are using (Admin-> Manage Components) and if you have made any mods? Current version is 1.3
wiproltdwiv
Re: Bandwidth usage
hi,
pls find the same
pls find the same
wiproltdwiv
Re: Bandwidth usage
we are getting graph after update latest version. i think previous version was with bug
Thanks for support
Thanks for support
Re: Bandwidth usage
Closing as resolved.
