Monitoring IT Watchdogs Temp Monitors
centwisit
Re: Monitoring IT Watchdogs Temp Monitors
Post by centwisit »
Funny you should mention that. I was clicking around in the device web interface and I can download the MIB in a .zip file. What do I do with it? IT included the attached .csv file and a .mib file.
mib.zip
(30.67 KiB) Downloaded 437 times
abrist
Red Shirt
Post by abrist »
You only posted the csv. Can you post the actual mib file as well?
centwisit
Post by centwisit »
Attached above.
abrist
Red Shirt
Post by abrist »
Alright, copy the mib file to:
/usr/share/snmp/mibs/
Then try:
snmpwalk -v2c -c <community> -M /usr/share/snmp/mibs/ <device ip>
Post the output in code wraps
centwisit
Post by centwisit »
My folder path was slightly different (I'm running ubuntu, not sure if that makes a difference). But here is the output:
iso.3.6.1.2.1.1.1.0 = STRING: "MicroGoose"
iso.3.6.1.2.1.1.2.0 = OID: iso.3.6.1.4.1.17373.3
iso.3.6.1.2.1.1.3.0 = Timeticks: (34852655) 4 days, 0:48:46.55
iso.3.6.1.2.1.1.4.0 = STRING: "[email protected]"
iso.3.6.1.2.1.1.5.0 = ""
iso.3.6.1.2.1.1.6.0 = STRING: "DataCenter"
iso.3.6.1.2.1.1.7.0 = INTEGER: 72
iso.3.6.1.2.1.1.8.0 = Timeticks: (233) 0:00:02.33
iso.3.6.1.2.1.1.9.1.2.1 = OID: iso.3.6.1.2.1.1.9.1
iso.3.6.1.2.1.1.9.1.3.1 = STRING: "The sysORTable capabilities are still being explored. It appears that the AGENT-CAPABILITIES macro in the MIB definitions should be used to generate these table entries. See RFC2580"
iso.3.6.1.2.1.1.9.1.4.1 = Timeticks: (233) 0:00:02.33
iso.3.6.1.2.1.2.1.0 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.1.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.2.1 = STRING: "eth0"
iso.3.6.1.2.1.2.2.1.3.1 = INTEGER: 7
iso.3.6.1.2.1.2.2.1.4.1 = INTEGER: 1500
iso.3.6.1.2.1.2.2.1.5.1 = Gauge32: 1000000
iso.3.6.1.2.1.2.2.1.6.1 = Hex-STRING: 00
iso.3.6.1.2.1.2.2.1.7.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.8.1 = INTEGER: 1
iso.3.6.1.2.1.2.2.1.9.1 = Timeticks: (0) 0:00:00.00
iso.3.6.1.2.1.2.2.1.10.1 = Counter32: 14765837
iso.3.6.1.2.1.2.2.1.11.1 = Counter32: 11817
iso.3.6.1.2.1.2.2.1.12.1 = Counter32: 159142
iso.3.6.1.2.1.2.2.1.13.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.14.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.15.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.16.1 = Counter32: 4580911
iso.3.6.1.2.1.2.2.1.17.1 = Counter32: 12722
iso.3.6.1.2.1.2.2.1.18.1 = Counter32: 405
iso.3.6.1.2.1.2.2.1.19.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.20.1 = Counter32: 0
iso.3.6.1.2.1.2.2.1.21.1 = Gauge32: 0
iso.3.6.1.2.1.2.2.1.22.1 = OID: ccitt.0
iso.3.6.1.2.1.3.1.1.1.1.1.10.1.1.30 = INTEGER: 1
iso.3.6.1.2.1.3.1.1.2.1.1.10.1.1.30 = Hex-STRING: 00 19 85 E0 B3 D5
iso.3.6.1.2.1.3.1.1.3.1.1.10.1.1.30 = IpAddress: 10.1.1.30
iso.3.6.1.2.1.4.1.0 = INTEGER: 1
iso.3.6.1.2.1.4.2.0 = INTEGER: 60
iso.3.6.1.2.1.4.3.0 = Counter32: 14951
iso.3.6.1.2.1.4.4.0 = Counter32: 0
iso.3.6.1.2.1.4.5.0 = Counter32: 0
iso.3.6.1.2.1.4.6.0 = Counter32: 0
iso.3.6.1.2.1.4.7.0 = Counter32: 0
iso.3.6.1.2.1.4.8.0 = Counter32: 0
iso.3.6.1.2.1.4.9.0 = Counter32: 14957
iso.3.6.1.2.1.4.10.0 = Counter32: 16797
iso.3.6.1.2.1.4.11.0 = Counter32: 0
iso.3.6.1.2.1.4.12.0 = Counter32: 0
iso.3.6.1.2.1.4.13.0 = INTEGER: 60
iso.3.6.1.2.1.4.14.0 = Counter32: 0
iso.3.6.1.2.1.4.15.0 = Counter32: 0
iso.3.6.1.2.1.4.16.0 = Counter32: 0
iso.3.6.1.2.1.4.17.0 = Counter32: 0
iso.3.6.1.2.1.4.18.0 = Counter32: 0
iso.3.6.1.2.1.4.19.0 = Counter32: 0
iso.3.6.1.2.1.4.20.1.1.10.1.1.30 = IpAddress: 10.1.1.30
iso.3.6.1.2.1.4.20.1.2.10.1.1.30 = INTEGER: 1
iso.3.6.1.2.1.4.20.1.3.10.1.1.30 = IpAddress: 255.255.255.0
iso.3.6.1.2.1.4.20.1.4.10.1.1.30 = INTEGER: 1
iso.3.6.1.2.1.4.20.1.5.10.1.1.30 = INTEGER: 65535
iso.3.6.1.2.1.4.21.1.1.0.0.0.0 = IpAddress: 0.0.0.0
iso.3.6.1.2.1.4.21.1.2.0.0.0.0 = INTEGER: 1
iso.3.6.1.2.1.4.21.1.3.0.0.0.0 = INTEGER: 1
iso.3.6.1.2.1.4.21.1.4.0.0.0.0 = INTEGER: 1
iso.3.6.1.2.1.4.21.1.5.0.0.0.0 = INTEGER: -1
iso.3.6.1.2.1.4.21.1.6.0.0.0.0 = INTEGER: -1
iso.3.6.1.2.1.4.21.1.7.0.0.0.0 = IpAddress: 10.1.1.30
iso.3.6.1.2.1.4.21.1.8.0.0.0.0 = INTEGER: 4
iso.3.6.1.2.1.4.21.1.9.0.0.0.0 = INTEGER: 2
iso.3.6.1.2.1.4.21.1.10.0.0.0.0 = INTEGER: 127
iso.3.6.1.2.1.4.21.1.11.0.0.0.0 = IpAddress: 255.255.255.0
iso.3.6.1.2.1.4.21.1.12.0.0.0.0 = INTEGER: -1
iso.3.6.1.2.1.4.21.1.13.0.0.0.0 = OID: ccitt.0
iso.3.6.1.2.1.4.22.1.1.1.10.1.1.30 = INTEGER: 1
iso.3.6.1.2.1.4.22.1.2.1.10.1.1.30 = ""
iso.3.6.1.2.1.4.22.1.3.1.10.1.1.30 = IpAddress: 10.1.1.30
iso.3.6.1.2.1.4.22.1.4.1.10.1.1.30 = INTEGER: 1
iso.3.6.1.2.1.4.23.0 = Counter32: 0
iso.3.6.1.2.1.5.1.0 = Counter32: 0
iso.3.6.1.2.1.5.2.0 = Counter32: 0
iso.3.6.1.2.1.5.3.0 = Counter32: 0
iso.3.6.1.2.1.5.4.0 = Counter32: 0
iso.3.6.1.2.1.5.5.0 = Counter32: 0
iso.3.6.1.2.1.5.6.0 = Counter32: 0
iso.3.6.1.2.1.5.7.0 = Counter32: 0
iso.3.6.1.2.1.5.8.0 = Counter32: 0
iso.3.6.1.2.1.5.9.0 = Counter32: 0
iso.3.6.1.2.1.5.10.0 = Counter32: 0
iso.3.6.1.2.1.5.11.0 = Counter32: 0
iso.3.6.1.2.1.5.12.0 = Counter32: 0
iso.3.6.1.2.1.5.13.0 = Counter32: 0
iso.3.6.1.2.1.5.14.0 = Counter32: 0
iso.3.6.1.2.1.5.15.0 = Counter32: 0
iso.3.6.1.2.1.5.16.0 = Counter32: 0
iso.3.6.1.2.1.5.17.0 = Counter32: 0
iso.3.6.1.2.1.5.18.0 = Counter32: 0
iso.3.6.1.2.1.5.19.0 = Counter32: 0
iso.3.6.1.2.1.5.20.0 = Counter32: 0
iso.3.6.1.2.1.5.21.0 = Counter32: 0
iso.3.6.1.2.1.5.22.0 = Counter32: 0
iso.3.6.1.2.1.5.23.0 = Counter32: 0
iso.3.6.1.2.1.5.24.0 = Counter32: 0
iso.3.6.1.2.1.5.25.0 = Counter32: 0
iso.3.6.1.2.1.5.26.0 = Counter32: 0
iso.3.6.1.2.1.6.1.0 = INTEGER: 1
iso.3.6.1.2.1.6.2.0 = INTEGER: 1000
iso.3.6.1.2.1.6.3.0 = INTEGER: 10000
iso.3.6.1.2.1.6.4.0 = INTEGER: -1
iso.3.6.1.2.1.6.5.0 = Counter32: 175
iso.3.6.1.2.1.6.6.0 = Counter32: 176
iso.3.6.1.2.1.6.7.0 = Counter32: 0
iso.3.6.1.2.1.6.8.0 = Counter32: 0
iso.3.6.1.2.1.6.9.0 = Gauge32: 1
iso.3.6.1.2.1.6.10.0 = Counter32: 137791
iso.3.6.1.2.1.6.11.0 = Counter32: 16554
iso.3.6.1.2.1.6.12.0 = Counter32: 53
iso.3.6.1.2.1.6.13.1.1.0.0.0.0.80.10.1.1.30.1034 = INTEGER: 2
iso.3.6.1.2.1.6.13.1.2.0.0.0.0.80.10.1.1.30.1034 = IpAddress: 0.0.0.0
iso.3.6.1.2.1.6.13.1.3.0.0.0.0.80.10.1.1.30.1034 = INTEGER: 80
iso.3.6.1.2.1.6.13.1.4.0.0.0.0.80.10.1.1.30.1034 = IpAddress: 10.1.1.30
iso.3.6.1.2.1.6.13.1.5.0.0.0.0.80.10.1.1.30.1034 = INTEGER: 1034
iso.3.6.1.2.1.6.14.0 = Counter32: 0
iso.3.6.1.2.1.6.15.0 = Counter32: 2033
iso.3.6.1.2.1.7.1.0 = Counter32: 8207
iso.3.6.1.2.1.7.2.0 = Counter32: 156
iso.3.6.1.2.1.7.3.0 = Counter32: 0
iso.3.6.1.2.1.7.4.0 = Counter32: 9298
iso.3.6.1.2.1.7.5.1.1.0.0.0.0.123 = IpAddress: 0.0.0.0
iso.3.6.1.2.1.7.5.1.2.0.0.0.0.123 = INTEGER: 123
iso.3.6.1.2.1.11.1.0 = Counter32: 991
iso.3.6.1.2.1.11.2.0 = Counter32: 961
iso.3.6.1.2.1.11.3.0 = Counter32: 0
iso.3.6.1.2.1.11.4.0 = Counter32: 30
iso.3.6.1.2.1.11.5.0 = Counter32: 30
iso.3.6.1.2.1.11.6.0 = Counter32: 0
iso.3.6.1.2.1.11.8.0 = Counter32: 0
iso.3.6.1.2.1.11.9.0 = Counter32: 0
iso.3.6.1.2.1.11.10.0 = Counter32: 0
iso.3.6.1.2.1.11.11.0 = Counter32: 0
iso.3.6.1.2.1.11.12.0 = Counter32: 0
iso.3.6.1.2.1.11.13.0 = Counter32: 971
iso.3.6.1.2.1.11.14.0 = Counter32: 0
iso.3.6.1.2.1.11.15.0 = Counter32: 55
iso.3.6.1.2.1.11.16.0 = Counter32: 950
iso.3.6.1.2.1.11.17.0 = Counter32: 0
iso.3.6.1.2.1.11.18.0 = Counter32: 0
iso.3.6.1.2.1.11.19.0 = Counter32: 0
iso.3.6.1.2.1.11.20.0 = Counter32: 0
iso.3.6.1.2.1.11.21.0 = Counter32: 25
iso.3.6.1.2.1.11.22.0 = Counter32: 0
iso.3.6.1.2.1.11.24.0 = Counter32: 0
iso.3.6.1.2.1.11.25.0 = Counter32: 0
iso.3.6.1.2.1.11.26.0 = Counter32: 0
iso.3.6.1.2.1.11.27.0 = Counter32: 0
iso.3.6.1.2.1.11.28.0 = Counter32: 985
iso.3.6.1.2.1.11.29.0 = Counter32: 30
iso.3.6.1.2.1.11.30.0 = INTEGER: 1
iso.3.6.1.2.1.11.31.0 = Counter32: 0
iso.3.6.1.2.1.11.32.0 = Counter32: 0
abrist
Red Shirt
Post by abrist »
Looks like it doesn't like your mib. You could try specifying the mib directly:
snmpwalk -v3 -c <community> -m /path/to/mib/itw_mibv3.mib <device ip>
I did notice that your are using snmp v3, do you have any v2c mibs available?
centwisit
Post by centwisit »
All I have is the MIB file.
Ran the above and got hte attached file as a result.
snmpwalk_results.txt
(111.26 KiB) Downloaded 601 times
abrist
Red Shirt
Post by abrist »
Looks like that mib relies on two other mibs:
Cannot find module (SNMPv2-TC): At line 7 in /usr/share/snmp/mib2c-data/itw_mibv3.mib
Cannot find module (SNMPv2-SMI): At line 9 in /usr/share/snmp/mib2c-data/itw_mibv3.mib
I would start by find those mibs and installing them.
