Now i'm wondering, is possible that the chec-host-alive which uses the normal ping command do not tollerate redirection?
Using check-fast-alive is a good way to check the status(up or down) of an host?
Good chance.
BAK wrote:Using check-fast-alive is a good way to check the status(up or down) of an host?
It should work just fine.
