XI Installation
Re: XI Installation
If you are a verified reseller you should have a license already available for you, please contact [email protected] regarding this and you will not need to reinstall.
Re: XI Installation
Hello Slang,
You are write we have given one Licence which we are planning to install in one of the dedicated server , but i have installed nagios in my linux laptop and it got expired so i though of re-installing it again.
As you said it wont be possible in the current linux machine.
Thanks For the information ,
Re: XI Installation
While we do try to support issues that arise during installations, if the guidelines are not followed there is not too much we can do but suggest to re-install following those guidelines. It is also never recommended to re-install nagios xi on a system that had it previously installed since fragments of the files and the existence of a database will cause quite a few issues as you have seen in your tickets with us.
