amakorju wrote:After i try to apply configuration (which won't work), it generates a duplicate nagios.cfg (.swp), timeperiods.cfg (swp) and commands.cfg (swp) in the /usr/local/nagios/etc folder.
Do you happen to have these files open on another terminal?
This is the error it gives after backing up and removing the timeperiods.cfg file
Error: Cannot open config file '/usr/local/nagios/etc/timeperiods.cfg' for reading: No such file or directory
You must have performed an extra operation, like removing a file and commenting out the timeperiod in question. Return the file to its original location and rerun the "write" and "verify" steps. Post the output of those steps in code wraps. DO NOT a"apply configuration" or "restart" nagios just yet, as if the apply fails, the old config will be once again written back to disk.
