You are correct, if this is for a HOST check, anything over 2 will be marked red.
HOST's do not have an "UNKNOWN" only OK, DOWN, UNREACHABLE
And the only way for it to be unreachable is if the hosts parent is DOWN
Ping without warning/critical possible (check if up/down)?
