Ngaiosxi admin password
tonyyarusso
Re: Ngaiosxi admin password
Post by tonyyarusso »
All right, try this:
There is a script in the /usr/local/nagiosxi/scripts directory that you can use to reset the password. Login to a shell as root and run the following command (replacing <newpassword> with the password of your choice):
php /usr/local/nagiosxi/scripts/reset_nagiosadmin_password.php --password=<newpassword>
Tony Yarusso
Technical Services
___
TIES
Web: http://ties.k12.mn.us/
p13589
Post by p13589 »
tonyyarusso wrote:All right, try this:
Finally i got it running. But I start all deamons, i get message that /usr/local/nagios/bin/npcd not found. So it does not start npcd. Does that mean any thing?
tonyyarusso
Can you manually search for npcd and let us know the results?
updatedb
locate npcd
Tony Yarusso
Technical Services
___
TIES
ashworth
Post by ashworth »
using the reset_nagiosadmin_password.php script worked for me, I then had to change the password as soon as I logged in.
rdedon
Post by rdedon »
ashworth wrote:using the reset_nagiosadmin_password.php script worked for me, I then had to change the password as soon as I logged in.
Excellent! Please feel free to contact us again if you require any additional assistance.
Thanks!
Rene deDon
Technical Team
___
Nagios Enterprises, LLC
Web: http://www.nagios.com
