Scheduled PDF Reporting failing to generate
KiwiBloke
Re: Scheduled PDF Reporting failing to generate
Post by KiwiBloke »
Results as follows:
[root@pfsunagiosxi ~]# ls -ld /usr/local/nagiosxi
drwxr-xr-x. 10 nagios nagios 4096 Jun  7  2012 /usr/local/nagiosxi
[root@pfsunagiosxi ~]# ls -ld /usr/local/nagiosxi/tmp
drwsrwsr-x. 2 nagios nagios 4096 Aug  2 13:48 /usr/local/nagiosxi/tmp
Actually we had a bug that I believe pertains to this same issue.
Can you install the attached file through Admin -> Manage Components
and try again.
KiwiBloke
Post by KiwiBloke »
That patch seemed to be the tonic that was needed. The scheduled report was emailed out aok this morning from that server.
I'll apply the patch to our remaining XI servers of the same version before they decide to have issues themselves.
Cheers,
KB.
abrist
Red Shirt
Post by abrist »
Great, let us know if you have any related issues with the rest of the patch rollout.
